Black stuff in fuel filter
Stitchit1
170
Cheboygan, Mi
L3200 has only one fuel filter. When changing it or rinsing with kerosene be sure to keep track of the two O-ring's on the top of the filter.
Jim,
I am only using one per dealer recommendations. However the filter has 2. The outer one and then one that’s appr 3/8” wide. You’re saying use both of these including the latter?
Jim L.
857
158
When taking the filter housing off, it is real easy to lose the small o-ring.
After changing or cleaning the paper filter, and inserting the paper filter into the housing, on the top of the housing there should be one large O-ring and one small O-ring each centered on the up-down axis.
Not wanting two small O-rings or two large O-rings. If the maintainer has the small and large O-rings when first removing the filter assy, then these O-rings may be re-used if not cut or damaged.
The O-rings are there to seal the diesel path going into the filter, and going back out the filter.
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
677
149
Rising Sun, MD
I am in the same pickle...
I have POL (i.e. Petroleum, Oils and Lubricants) algal contamination. 100% sure... I did a microscopic examination.... you can see the cells!:mad: The following will let you know exactly how big of a pickle I am in and my proposed plan of attack.
I fill my tractor fuel tank after each use to prevent water condensation. I still got algae.:mad: The critters REQUIRE water to thrive and are anaerobic as they grow in the water layer UNDER the oil. I am pretty sure it is in my bulk fuel tank (275 gal Danby home fuel oil upright steel tank). It is located in my shop and never exposed to the weather. About once a year I fill it to a max of 200 gallon per fill. Actually... I top it off with about 170 gallons to the 200 gallon level.That gives at least 75 gallons worth of atmospheric free board above the fuel. I have a sealed fuel delivery system. I pump oil from the bulk tank with a dedicated hard piped diesel pump and regular gasoline fill nozzle... like you see at a gas station. I have a Fram can filter between the bulk tank and the pump. Given what I know now about the critters cell size,,,, the filter is useless as tits on a boar hog as it ONLY captures clumps.
Now this is where I think I screwed up.
The bulk tank is vented directly to the atmosphere through a regular 2" screened vent cap 24/7, like a regular fuel tank 24/7.
Me and the bulk tank reside in Maryland where the humidity can range from the low 30%'s to like now 94%. The corresponding temperatures can range from like 46* F overnight (like a couple days ago) to 92*F right now.
This is how the water is getting in the bulk tank. Continuous water vapor condensation is believe this is the root of my algae problem.
The solution, first super clean the tank with some sort of oscillation spray nozzle by drawing the fuel level to around 20 gallons, enough where I can still draw with the pump without cavitation. Dose the tank with a good diesel biocide, tie wrap a sock filter something like a pillow case or actual sports sock to the delivery nozzle stick it in the tank (2" threaded opening)and turn on the pump ... let her circulate. Gotta get as much of the clumps out as you can.
Once I get everything in the system as clean as I will discard the 20 gallons of circulation fuel and then refill with a fresh 200 gallons of fuel.
To alleviate the condensation in the bulk tank I will fabricate a desiccator on the tank vent line. The desiccator anhydrous granules are whiter when you first install it. As they absorb water vapor from air entering the tank... it will change color like to a pink. That's when you know to replace it with fresh granules. The granules can be reused... you can spread them out on a cookie sheet, pop them in your wife's oven at about 425*-450* F till they turn white again... then you are off to the races!
There is one more thing I plan to do.... replace the kubota fuel with a Racor fuel/water and a ball valve in the fuel supply line from the tank.
I still have no idea what Biocide to use to clean and dose my bulk tank with.:confused:..
What do you all think... any other ideas... suggestions
Jim L.
857
158
Butch, sorry to hear you got critters.
Think that you will need to get volumes of both the main tank and any machine tanks. Dose of biocide into an individual tank will depend on these volumes. Dose each tank with biocide according to total tank volume and then fill each tank to the max with diesel. Time will be what it says on the data sheet for the particular biocide.
The dead bodies on the bottom of the main tank. Can be sucked up and filtered, putting diesel back into tank.
From now on, you will have to use biocide in your main tank. All you can do is to keep the population down to keep the bodies from clumping up.
OlFerguson
4440, 1120D
Jun 1, 2017
192
11
That new diesel fuel they produce is nothing but a pain in the ass. You will need to dismantle the entire fuel system and drain everything and clean everything. My personal preference for cleaning the fuel system is kerosene and Howe’s treatment. Keeps things running smooth.
Where do you store your fuel ?
Butch
Sep 10, 2009
677
149
Rising Sun, MD
Yep ... that is kind'a what i thinking...
