BH92 backhoe hydraulic connections with existing 3rd function, on my L4060
Gnlandrus
Kubota L4060 HST CAB
Apr 15, 2025
Reno NV
I’m new to the forum and need some help.
I recently bought a 2019 L4060hst with a front loader and a 3rd function installed.
I am having trouble figuring out how to plumb the hydraulic lines for the backhoe. Any/all help is greatly appreciated!
Thanks, Greg.
1,723
There should be a couple of hoses connected together making a complete loop. One hose will have a male end and the other will be female so it is possible for them to be connected.
The backhoe should have connection points to match the hoses and supply flow to and from the backhoe valve.
I am assuming that the backhoe was already installed on the tractor before and you are not adding it as “new”.
Gnlandrus
Apr 15, 2025
Reno NV
Thank you for your reply!
Yes, the backhoe was on a different model Kubota.
My used Kubota L4060 has a 3rd function added to it. It looks to me like the 3rd function hydraulics connect below the driver seat. I was wondering if I can add a couple of tees to those lines to use as the hydraulic feed and return for the hoe. That would be before the solenoid that activates the 3rd function.
What do you think??
4,813
What do you think??
No. You supply ths backhoe from the pressure return port on the third function valve. Post a picture of the third function valve connections so we know what you currently have.
Gnlandrus
Apr 15, 2025
Reno NV
Here are the pictures of the current hydraulic setup on my L4060.
first picture is under the seat, looking towards the back of the tractor.
the second pictures are of the 3rd function valve & solenoid assembly.
Where should I hook up the hydraulic hoses to power the hoe?
Gnlandrus
Apr 15, 2025
Reno NV
I am adding it as a new installation on the tractor. I’m installing the hoe subframe and the mounting brackets, as well as the hydraulics for operating the hoe.
thank you.
4,813
I wish I could answer that question.
After looking at the WSM for the Grand L 60's it appears the rear remotes are fed by that 3rd function. I dont see any way to connect after them.
A BH92 installation guide seems to be where we will find the answer and I dont have one. Perhaps @whitetiger can illuminate us.
