Best ideas for adjustable lifting strap or chains?
icehorse
L3901, box blade, tedder rake, mini round baler, drum mower, rotary cutter, misc
Aug 10, 2022
119
25
I don't lift super heavy stuff with my little 3901, but you know 500 pounds here and there.
I have some big towing straps, but I don't have a good way of adjusting their length and then un-adjusting it ;)
I added hooks to the top of my FEL bucket, so that helps.
I kind of like the nylon straps more than steel chains, but I'm open to ideas. Again, ADJUSTABLE LENGTH is essential.
JasonW
394
197
Al
What types of items are you lifting?
You already have bucket hooks. So my vote goes to 5/16 chain.
icehorse
Aug 10, 2022
119
25
Miscellaneous small farm stuff. Implements, pallets of stuff, old washing machines, 80 gallons of water in a tank...
GrumpyFarmer
3,596
I’ve got same set up as Tractor Mike suggests…it works great for me.
It’s not adjustable, but having a couple different lengths give you some options.
Here’s a video, maybe this gives some ideas?
1,732
For taking length (slack) out of the chain I use two grab hooks that are joined together.
one like this
and one like this
put the pin through the hole of the first hook and use the two hooks to grab links of the chain.
Reactions: 6 users
BXHoosier
BX24
Jan 21, 2018
490
566
Indiana
I’ve used ratchet straps for adjustable lift straps. It’s obviously not their intended use, but lifting 500 lbs with a 2” strap rated for 3,300 lbs should be fine as long as you have a few wraps on the spool so it doesn’t slip.
g_man
Feb 3, 2023
214
976
NE Vermont
I like to use straps unless chains are clearly a better option. I have a pair of 4', 6', and a 9' that I use logging so they are on hand. They work good with a tooth bar or grapple. Happened to need a battery charge out on the landing today so took a picture.
While talking straps - if you ever need to connect two together then put a dowel in the joint so they come apart easy.
gg
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,515
1,967
Western MT
Use a short length of chain with a hook to take up length. It's obviously easier to loosen compared to almost anything else once the load is lowered since you only need to take the chain out of the hook.
For hooking to the load, I use a D-Ring with strap or chain depending on what I'm lifting.
Old Machinist
May 27, 2024
269
279
NE FL
Chains on bucket hooks are the way to go. For 500 lb lifts you would be fine with 1/4" chain. I have a pair of 1/4" in my John Deere tool box and 5/16" chains in the Kubota. I have picked up my 1100 lb generator with the 1/4" chains and the John Deere. A couple of 10 footers is all you need. Super easy to choke up on the bucket hooks assuming you put chain hooks on it and not the rounded slip hooks.
FYI Walmart has a good price on metal ammo boxes. They work great for tools and chain storage.
icehorse
Aug 10, 2022
119
25
Got my 20', 5/16 chain. Used it yesterday to lift a 5' disc harrow off of a trailer, worked great :)
JRHill
Orange: B7100 Std and Woodmizer; Green/yellow JD Buck, Gator and 410j.
Apr 26, 2016
212
159
Wahkiacus, Washington
I've welded hooks on my loader buckets for convenience. But nothing is more important than the risk of failure at the job at hand. Case in point: I recently filled a 100g tank of diesel (again) and had to get it out of the pickup box. I USED LIFTING STRAPS. Cheap, Harbor Freight with a chain to the loader. The straps are rated for more than the 410j can lift and threaded with the logging chains. All this stuff is relatively inexpensive. Why does one jury rig?
For me having a ruptured 100g tank of diesel from a tow strap is unconscionable. But sometimes there is an emergency - then you do what you can. But prepare, have some stuff for what you might encounter. I don't drag logs with lifting straps.
Hoserman
Aug 1, 2022
Grayling, MI.
I'm a big fan of wire slings, nylon slings and chain with grab hooks. But for me the chains win out for adjustment capability.
jaxs
B1750HST
Jun 22, 2023
871
662
With tractor all the time and handles 90% of tasks is 15' 3/8" chain w/grab hooks, 5' 3/8" chain w/grab hooks and two 12' 2.5k ratchet straps. Other chains , cables, straps, snatch blocks and winch stored in barn until needed. If I used tractor daily for logging or other special purpose, gear might look different.
Kennyd4110
Vendor Member
Sep 7, 2013
1,325
618
Westminster, MD
www.boltonhooks.com
jyoutz
Jan 14, 2019
3,322
2,349
Edgewood, New Mexico
Bee-Positive
Nov 16, 2022
122
148
Amsterdam, NY
100%
Never lift with a tow strap. They are made to stretch and rebound using stored energy to add in pulling. Lifting straps are not. If you use a tow strap because nothing else is available you may get lucky but don't be surprised if it fails.
icehorse
Aug 10, 2022
119
25
Based on the advice in this thread I got 20 feet of 5/16 chain with hooks on the ends. And I got a pair of slings. I've lifted a few things in the 500 pound neighborhood and it all felt very secure.
thanks
JRHill
Apr 26, 2016
212
159
Good for you. I use logging chains for most stuff and lifting straps if I have to go there. Sometimes a cable but I am really cautious with them.
I have logging cables salvaged from the hills. I have seen how they failed. I am really shy about snap back. In the hills I have found cable chokers that are 5/8ths cable and extension cables with connectors. I don't worry about 5/8ths cable pulling with a 410j. I could have the tractor from a tree with those.
