Best finish mower for an L3901?
thedevilyoulove
L3901 HST with LA525 FEL, Land Pride RCF2572, pallet forks, 3 pt carry all
Jan 27, 2016
143
Woodbine, Maryland
Looking to pick up a three point hitch finish mower for my L3901. It does not have a mid-mount PTO so the mower must be a 3 point hitch type. I am sure a 6 foot would work since I have a 6 foot Land Pride Rotary Cutter, but I am wondering if I can go larger than 6 foot for a finish mower. In addition to the size, I'd like some recommendations on what finish mowers you guys like. I prefer Woods and Land Pride.
A guy a few miles down the road is selling a woods RM990, but it's a 9 foot cut and I am thinking that's way too big although he is telling me it would work fine.:rolleyes:
4,701
I have a 60" finish mower that I run behind my 15hp l1501 :D since your running almost triple the hp you should be able to handle the 6 footer easily.
You should see if he will let you demo the 9 footer to see if it will work ;)
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
My L3000 handles a 6' mower just fine so you could go a little bigger if you want but you better have pretty flat ground. From my experience the wider the mower the more it will scalp on uneven ground.
Brand, I suggest Bushhog. I have been using mine since the summer of 2000. Only repairs I've made is replaced the bushings in the wheels with the roller bearing kit they offer. I would buy another Bushhog brand mower if I ever wear this one out.
TripleR
Sep 16, 2011
1,911
SE Missouri
We have a 7' and 8', you won't have any trouble with 7' or maybe even the 8', for me 9' is just not practical.
Ours are old Caroni mowers, but if I was buying now, I'd go LP or Woods. not familiar using other brands.
Benhameen
Jan 27, 2013
689
115
Southern IL.
6 footer works great for me, im sure the tractor will handle a bigger one though, as Bulldog said a wider one is going to scalp on the uneven parts of your yard. I too have a caronni that is pretty old. I bought it used to see if a finish mower was going to work for me or not, it does by the way. I looked at a used 7ft LD last fall, should have bought it but didn't. oh well the old one I have still cuts pretty good.
5,277
A woods RM990 is not 9' it's 90" or 7.5 foot.
Regardless it's still too big it's a 45 to 75 HP requirement, and your only putting out 30.6 HP.
rjcorazza
Mar 9, 2016
778
22
Hyattstown, MD
I ran a 7' finish mower for years behind an L3410 without issue. I looked at several brands and decided on Befco because it appeared to be better constructed. It has been problem free for a long time, and now rides behind an L4060.
Sammy3700
L3800HST,524Loader,BH77,Landplane,Disk,Mowers and more
Feb 20, 2012
428
35
Red Springs, NC
I have a L3700SU and a 6' Caroni, My dad has a L3800HST and a 6' Woods and both work great. I think the L series is rated for a 7, however I agree with the others about scalping if your ground is not level.
cn2redjeep
L3901, tiller, finish mower, pallet forks, rear blade
Mar 27, 2015
25
Illinois
Land pride 6' painted to match my L3901 $2800.00. Heavy duty and does a good job. But the finished quality is not a "golf course" perfect mowing job. I did have to replace a belt, using it like a bush hog and not like a finish mower.
