belt replacement
HUDDY
kubota zero turn 421
May 1, 2024
ARKANSAS
hello....i have a kubota Z422 ...54 inch....100 hours...bought last year....i have replaced 2 belts on mower this year...100 dollars a belt ...i have less than 30 minutes on new belt and can smell rubber burning....i have checked spindles and they are all turning smoothly changed bearings on 1 because of dust cover underneath was cracked .... that didnt help...any suggestions would be appreciated
5,288
Either something got bent and is misaligning the belt or more likely you have a bearing in a tension pulley that is going out.
3,089
Changing belts (2) on a Craftsman lawn ”tractor”….. This looked like a 20 minute job.
Four hours later….. still puzzled why new belts don’t fit…. too loose. Checked PNs… Correct PNs.
Checked Mx Manual diagram for belt-routing…. Yep, looks right… but belts still too loose.
One belt drives HST…other drives blades…. Whoops! Printed belt-routing diagram not accurate. Should have taken a pic before removing the old belts. Younger son-in-law figured it out. 🤒
One of the puzzling things about spindle bearings on my finish mower…. the spindles have a grease-fitting/zerk on top…. greasing them fills the spindle-shaft-case full of grease….but the bearings themselves are sealed bearings. No way that filling those spindles with grease does anything at all to lubricate those bearings.
A YouTube presenter demonstrates removing one of the plastic seal on the bearings so grease can get to the roller/balls. Hmmmnnn……
4,139
possible problem....
Carefully check the 'tension arm'. You've got 7 pulleys that need to be lined up.
Went through 3 or 4 belt on an AC130 last year and FINALLY clued in that the 'tension arm' was 'wobblely' on it's pivot shaft.Maybe the PO never greased it ? Spent an hour getting it firm and silky smooth, NO up/down play. Put new belt on, went and cut 1/5th ac of 12" tall grass NO problem.
Belts should run in center of 'flat' pulleys NOT to one edge. Also look to see if spacers/washers/shims ARE on the correct side of pulleys. Seen that before as well...oopsy.....easy to do.
