Bio-Bor JF is a 20-Mule Team product….approved for use in jet-fuel aircraft…so it’s almost good enough for my Kubota.
![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
(I use it to treat the diesel in my storage tanks.)
Spores from yeasts (think of sourdough bread recipies) live in the air. As fuel is consumed…atmosphere enters the tanks. (Air above the fuel level in fuel tanks is called “Ullage”.)
The spores enter the condensation which occurs on fuel tank walls…and settles to the bottom of the fuel…where the spores germinate and grow…living in the water…eating the fuel…and POOPING their waste-products which is slimy and creates “mats” of slime (often mistakenly called “algae”). It clogs filters, injectors, and is corrosive to pumps, and tanks, etc.
Follow the directions CLOSELY if you use a biocide. Some of them, if merely “dumped” into the fuel instead of being introduced to the the fuel-stream when filling the tanks…will form “globs” of jelly and not perform as intended.
