Back Blade Size
pauly
2014 B2650, LA534A FEL,B2781B Snow Blower, Land Pride RCR 1260 Land Pride RB157
Sep 23, 2014
150
East Troy Wisconsin USA
Looking for a little advice from the more experinced folks.
I have a B2650 and want a back blade for snow removal and driveway maintenance. What size, 60" or 72"? Do I want the tilt feature? I may never need it but it may come in handy. I do plan on maintaining a small MX track. Should I stick with a Land Pride or look at other brands too?
Thanks.
Paul
5,277
Landpride 60" with tilt will work great all around.
If you find another blade of the same build for cheaper you could go that route too.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
I used a 72" RHINO blade for 35+ years with an L185DT, without ever having a problem. It is very good for snow plowing! Tilt is too extreme for most uses, unless you think you may someday do ditching. I've only used it once in the time I owned it, for a neighbor. For crowning a road, etc. you just vary the height of one of the lift arms.
Having swing or offset is quite handy for snow - it allows you to push the snow berm well outside of the tire tracks. This will be a must if you get a 60" blade - they get narrow in a hurry when you angle them.
