Once you get your transmission squared away, it's critical you properly adjust the deck limit linkage per the manual. If it's adjusted correctly, the deck can't drop low enough to uncouple the slip-shaft. The same is true when raising the deck. If not adjusted properly, you can raise it too high and smash it into the bottom of the machine with enough force to bend or break something.
