I’ve had issues for a while now with my 3 pt. It pops the snap ring on the left side of the shaft (50), the shaft migrates right, and the left lift arm falls off. The only thing I can figure at this point, is the groove in the shaft has been damaged and not holding the snap ring. My though was to remove the shaft for inspection/replacement.
No....unfortunately I don’t have a wsm......
I removed both fenders for clearance, and both lift arms, the shaft will only slide to the right...but won’t easily come out of the hydraulic arm (110), although at this point I have not tried much persuasion.
Anyone else done this? Any alternative to ripping the whole top off of the pump? Any help appreciated.
