Hi, sorry I have not been very clear with this post, I have a alternator already fitted to my engine but my voltage regulator is not working, I'm getting too much voltage at the battery which seem to be cooking my battery.
So I thought if I replaced the original voltage reg with a new modern one that would be the problem solved. But I don't know what to replace it with
Thanks Rich
Rich, you were right when you asked your original question, a non mechanical regulator is called a solid state regulator.
There are generic solid state regulators out there in the market, problem being they are made for an alternator and not a dynamo.
An alternator has parts internal to covert the AC output voltage to unregulated DC and then the solid state regulator can do the work, but a dynamo just puts out an unregulated AC signal.
Now if you really want to do it, along with a solid state regulator you will need a bridge rectifier (cheap and easy to work with).
You would wire the two output wires from the dynamo to the bridge rectifier then the output of the bridge would feed power to the regulator, and then the regulator feeds the battery.
So it can be done just takes a little more work to do it.
