Hi
Oil seals are standard components and you do not need to go to Kubota. They are available on ebay or from any bearing supplier. you need to measure the internal diameter, outside diameter and thickness in mm and order them.
Good luck
Paul
Hi
Good luck
Paul
True…. but I was impressed with the Kubota replacement seals…. they were "double" seals….. a lip to keep the oil in & a 2nd lip to keep dirt out.
Kubota part #66611-17120, at least here in the US.
