Thanks for taking the time to respond, but, I don't think you understood my question. I may not have been very clear. Using a tapered nut or a regular nut with washers does not effect your ability to change your wheel base width. It effects how well "centered" your wheel is on the hub. With the holes in the wheels being larger than the studs, if you use a tapered nut, when it is tightened it centers each stud in it's hole. If you use a washer and normal nut it does not. I wondered if it came from the factory without a tapered nut or if maybe it had been changed by someone in the last 20 years. The holes in the turf tire wheel are shaped to accept a tapered nut.
When putting the wheels back on yesterday I realized the nuts ARE tapered on one side, but, were being used with the flat side with the washers. I am going to just use the nuts tapered side toward the wheel and not reuse the flat washers and locknuts, because it just doesn't make sense given the wheel design. Maybe they are used on the wheels for AG tires, but, they sure don't make sense on the turf wheels.
