B7000 valve cover gasket????
kaze
Kubota B7000 Cub Cadet 1782 Cub Cadet 78D York Three point rake Woods RM 400 mo
Tried google and epay but no luck finding a gasket
Would like to adjust the valves. A previous owner for some reason removed the rod for the compression release. If I get the cover off I will see if the rest of the release can be removed. That is something someone will use to burn a valve.
But first I really need to find a gasket for the cover.
I tried local repair shops that do the refrigerated trucks. I found out a long time ago that the units used the z650 engine. But no luck on that one.
If it is any help the engine number is
Z650-2807
kaze
pretty darn close to it. The only difference I can see is the breather bolts to the box.
Got a good shot of the prev owners muffler repair
Not that I blame him that thing is expensive.
Will leave you know ordered b4200 4wd
15261-14520 gasket
15521-05670 breather filter
5,128
Sorry to hear it didn't fit.
Sounds like there isn't any other engine like that one. :(
