kaze
Kubota B7000 Cub Cadet 1782 Cub Cadet 78D York Three point rake Woods RM 400 mo
I Found a B7000 with a Woods RM 400 Mower. Mower is in good shape blade fine. Bearings tight oil in the gear box. Lubed and put on a new belt; wish I were 50 # heavier.
Bad part after making three passes in the yard it sounded strange. Back to the shed. Checked the oil level and low and behold it is over full. Lucky it was not a VW or it would have sucked the oil in the engine and ran away. But trying to figure out where it would be coming from. No foam a tad bit thin. Radiator was low but still no foam when I drained the oil. Checked the trans dipstick it is still full of the hydraulic oil. This I think sometimes not well or else would not have bought it. There is a fuel pump on the side of the injector pump. It has to be that or the injector pump causing the dilution??? If it were an injector would the engine not show it?? You fellows are smarter than I am could use a starting point on how to check the fuel pump or the injection pump
HELP
HELP
