HI everyone!
I just brought down a non running B6000 from the Nevada desert. It came with a tiller, box scraper, and FEL. I'm still busy cleaning it up before I can run a compression test .....(preparing for the worst).
This one is missing the fuel pump. The fuel line is routed like it should be with the filters and all, except that it bypasses the spot where the fuel pump was.
Here's my question. Can the B6000 start and run without the fuel pump? The previous owner said it ran fine that way, but I'm just curious if anyone else has a gravity feed setup. I thought injector pumps needed a minimum amount of pressure to function.
Your input is much appreciated
Thanks!
Thanks!
