B3200
Sammy3700
L3800HST,524Loader,BH77,Landplane,Disk,Mowers and more
Feb 20, 2012
428
35
Red Springs, NC
Anyone have a B3200? My neighbor has found one just over 100hrs. He has been looking at the B2601. The b3200 has more hp and does not have the computer. I have zero dealings with the B series so thanks for any input.
2,207
The B3200 has been around for almost ten years .....great machine.
The B series is perhaps the best selling series of all time......I could be wrong , but the series has been a fantastic one over the last almost 50 years!:D:)
MattN03
2011 B3200, LA504 FEL w/B2366 SSQA conversion, BH76 BH, EA Wicked 55
Sep 5, 2016
222
40
KY
I bought a 2011 B3200 a few months back. It had 78 hours, it was like new. I have about 125 hours on it now. It's a nice little tractor, that is very manuverable in tight spots (like our woods), but big enough to get work done (has a BH76 BH too).
Gr333
B3200, La504 Loader, Bh76 Bh
Feb 16, 2016
Bluemont, Va.
I bought my B3200 in 2009 with loader and backhoe. Have now around 500 hrs
and no issues with machine. It gets the job done. Only major complaint in the service area is cleaning transmission strainer. Not a issue if you do not have a backhoe, with backhoe you have to 1) drop backhoe 2) remove sub frame for backhoe to get strainer out. Kubota Should have designed a hole in sub frame to
accomplish access to strainer. You might also check rear wheels for spacers as they will be needed if you want to run chains in winter.Not to big,not to small.
kuboman
725
Had one for 8 years and 0 problems. Great machine with lots of power for the size. Only complaint I have is it has the 4 cylinder vibration that can be annoying at pto rpm. Other than that minor complaint its an excellent machine and I wouldn't hesitate to buy another if so needed.
mport
2013 B3200 backhoe
May 9, 2014
27
ST. Clairsville OH
They must have changed something on the newer ones. I removed and cleaned the trans screen on my 2013 B3200 without removing the backhoe. It was tight but can be done. Have about 300 hrs on mine with zero problems. Great machine!
