B3200 Front Lug Nut Pattern and Lug Size
Rugman
Kubota B3200
Feb 3, 2021
Holland, NY
I have a B3200 and would like to purchase a set of wheel spacers. I cannot find the lug nut pattern nor the bolt size of the lugs. Any assistance would be most appreciated.
5,271
You NEVER put spacers on the front!
It does nothing for you, except increase the likelihood that your going to damage the front end.
3,078
Since the front axle pivots with terrain, adding spacers to widen the track does nothing for you except to add stress-loads to the driveline and axle-housing.
Rugman
Kubota B3200
Feb 3, 2021
Holland, NY
Thank you for the replies. I was asking because the winter chains hit the frame even after flipping the tires inside out (and yes opposite sides). I guess I will just deal with it.
5,271
Do they only hit when you turn sharply.
If so you need to adjust the stops.
Rugman
Kubota B3200
Feb 3, 2021
Holland, NY
Yes, I will look into that. I want to say that the tires would hit the frame even with out the chains, so I turned the tires inside out and rotated them and it improved slightly. I will check the stops. Thank you.
2,396
I know your tractor is not a B 26, but you might want to read the following thread:
Sammy3700
L3800HST,524Loader,BH77,Landplane,Disk,Mowers and more
Feb 20, 2012
428
35
Red Springs, NC
My neighbor has a B32000 turf tires with a mid mount mower and they do not hit anything when stops are set correctly so please look at these as others stated no spacers and put the wheels so the are dished inwards
5,271
If I remember right if the tie rod is not adjusted properly it can cause that issue.
