B2650 question
bluefin650
B2650, JD 35D
Feb 28, 2018
Southern Maine
I have a 2650 with 10hrs on it. When I got the tractor, I was using a front mount snowblower on it. When I would scroll through the display to get to the mid pto screen, it would display pto speed at 540-560rpm. Now when I am using the mid pto ONLY, the rear pto screen displays the pto speed at 540-560rpm and the display screen for the mid pto displays engine rpm along with the normal display screen that displays engine rpm. I had my dealer pick up the tractor to check it out. The tractor was dropped back off today so I checked the display. No change. I called the dealer and I was told that this was the normal operation of the display. I am not buying the explanation. The manual says Mid PTO speed for the display.
So, What do you guys say in your display when you are running the mid pto and on the mid pto display screen?
5,475
You do know that mid PTO speed is not 540RPM, Its 2500RPM.
So looking at the display and seeing what you think is engine RPM would be right for the MID PTO.
Rear PTO is at 540RPM. ;)
3,323
as wolfman stated, the mid PTO speed is engine the engine speed. The little tractor indicator above the speed indicates which pto speed is being displayed. If rear, then 540.
