B2410 - font axle bolt - does this look right?
cwl3
39
Hickory, NC
I've been going over my recently purchased, very used B2410 and noticed the front axle bolt looks a little strange. Is this correct?
Thanks,
Calvin
5,298
Yes it's normal and right, it's an adjustment bolt for thrust adjustment.
The bolt 70 pushes on thrust plate 60 and the nut on 70 is used to lock it in place.
ndkubota
B2410 HSD
Mar 21, 2016
Watford City
That is your front axle pivot adjustment.
"If front axle pivot pin adjustment is not correct, front wheel vibration can occur causing vibration in the steering wheel"
Adjusting procedure - Loosen the lock nut, tighten the adjusting screw (tightening torque 20 N-m, 2.0 kgf-m, 15 ft lbs), then loosen the screw by 1/6 turn. Re tighten the lock nut.
Page 64 of your manual
cwl3
39
Hickory, NC
Thank you - you guys are a huge help. I'm going to join as a paid member just got the awesome advice I've been given!
Thanks!
