B20 Hydraulic oil in engine
Cloud
Kubota B20
Aug 5, 2014
22
Dalton Gardens, Idaho
I keep getting hydraulic oil in my engine. i have replaced the seal in the hydraulic pump several times but it keeps happnening. what could be causing this? Pressure too High? how do I correct it? Thanks for any help.
3,505
If you have replaced the seal multiple times and it is stil leaking sounds your pump needs more than a seal. I would guess worn seal area on the shaft and/or possibly worn bushings that allow the shaft to wobble taking the seal out.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
If replacing the seal is not correcting the problem I'll agree with Dan, it may be time to replace the pump.
Cloud
Kubota B20
Aug 5, 2014
22
Thank you for the help. The shaft was scored so I cleaned it up and swapped the bushing for one that was tighter and it works great now.
