Titan17
L3901 TLB, Caroni RFM, Scag Wildcat ZTR, Piranha TB,York RE 96", MTL HD 48" grap
Hi all. Been a while since last posting. As usual you hear from some people only when they have problems; I'm one of them.
After 3 years with no tractor I'm finally moving to our previously rented farm property.
I bought from a friend an old B1750 D w/fel and RFM for property maintenance. Only 621 original hours near perfect condition and everything functions as it should except 3PH.
The loader control needs to be jiggled then it lifts fine. It lowers fine also
I guess it's an OC spool with float detent. I cleaned, replaced ball and reassembled detent. Tractor sat for long time and it only occurs occasionally but since I'm mowing with a rear RFM I'd like it to be dependable.
Anyone have insight on this issue?? Maybe disassemble to clean spool, maybe some use will fix.
For machines that sat for long periods - I've used them a bit and problems self correct. This might be the case.
Fluids changed, screen cleaned, loader works fine.
Any and all comments appreciated.
