B1500DT Tickover
Stanlmic
B1500
Dec 7, 2023
England
Ive just fitted a tacho to my B1500 and discovered that the ticker is running too fast - around 1700 rpm does anyone know how to adjust it as its not obvious to me currently. What should normal ticker speed be ?
2,280
Let's see if we understand what you mean.
You placed a new trach on your B1500 - Is this an aftermarket tach? A hall effect tach? OR?????
Stanlmic
B1500
Dec 7, 2023
England
Yes aftermarket - eBay special, Its a hall effect tachometer with a proximity switch mounted close to fan belt pulley that senses a magnet.
I believe the new tachometer is measuring / displaying the correct speed, so I'm looking to understand how I can reduce the ticker speed of B1500 engine.
2,280
What pulley did you install the magnet on? Crank ? or?
And I are you looking to reduce idle speed?
Stanlmic
B1500
Dec 7, 2023
England
Installed magnet ion the crank.
Yes, I'd like to reduce the idea speed, not sure what it should be on this model but think 1700 that it currently is is too fast.
5,480
There will be a screw on the throttle control that adjusts idle speed.
