Here is a picture with some r4's, but no fel
Those would be a couple hovercrafts we've built, unfortunately they've been setting for a couple years and need some work, but I'm hoping to get the small one working this winter so I can play in the snow with it a bit.
If you don't know much about hovercrafts, the black "tube" around the bottom is the skirt. There is a fan which blows air under the hovercraft, and some of it inflates this skirt to make a seal with the ground, the rest of the air is dump inside the skirt creating a cushion of air that the hovercraft floats on, pretty much eliminating all the friction with the ground. Then you usually have a prop to push it, rudders to steer it.
I got into building them from plans from Universal Hovercraft (
http://www.hovercraft.com) with my dad when I was in high school. We built a small 10hp single person hovercraft, then a large subaru powered 6 person hovercraft that would do 70mph or so, and you could also build wings for it and fly it (we were never that brave
We ended up selling that larger hovercraft for a nice chunk of change and tried to start up a hovercraft business. We built the two red hovers as prototypes. I designed every part of them (well minus the engine), and we built both of them, hopping to one day sell plans and maybe kits. In the mean time I sold parts and components (along with woodworked) to work my way through college, but then I got a "real" job, married, etc and life got in the way and we never got any further than that. Then the recession took a big hit on the hobby and we stopped selling parts, and didn't have the money to hover for a while, then we didn't have the time....... Now they need some work to get them going again.....
The larger one has a 27hp engine to push it and a 10hp to lift it and will do about 55mph, and the smaller one has a single 14hp engine with a direct drive lift fan, and belt driven thrust prop, I built the fan and prop on this one our of foam and glass to save some weight.....
You can see more pictures and info at my website:
http://www.zbcreations.com/
Sorry for taking over your post pauly, but I'm glad my block heater post helped you out!
Hey, ZBHover:
Tell us about that ORANGE thing you're driving in your member identification block to the left of the text box.
Looks interesting.
But does seem to be missing the front loader.
And tires! R1, R4, or R-zero?
-Stubbyie
