I finally got around to getting my auxiliary lighting on my BX. It gets dark at about 6 pm here now, and I know when the snow finally hits I'll need more than the headlights when using the loader (they are in exactly the most inconvenient place when using said loader . . . .)
I got 3 35W sealed beam tractor lamps and using loom, a couple scrounged connectors from the junk pile at work, a junction block and some sealing-style heat shrink tube and built a full subharness for them. As an automotive tech who hates it when engineers don't consider serviceability, it would be disgraceful to "hack it in."
I opted for a junction block as opposed to inline fuse holders for the lights, but use a large inline fuse holder near the battery post. The harness was snaked along a factory harness to the rear. This put one weather-pak connector at the bottom of the ROPS, so it's easily unclicked if/when the ROPS has to come off for service. The other connector is up top near the lamps. The lamps are held on using NutSerts, which are the cat's meow when it comes to tubing. I put the switches in the dash near the blank hole where the cruise control is on higher up models.
I know, I drilled the ROPS. However, the NutSerts fill and crimp onto the hole, so I'm not worried about structural failure, especially since I painted the bare metal and sealed the lamp bolt threads.
As for the wattage, the factory headlamps are 37.5W each, and I don't turn them on with the loader anyway because they glare on the bucket. 35W @ 12V ~ 3A per bulb, so I'm not too worried.
Worlds different while using the loader now!
