Another 1st Time Buyer Help Thread
8,226
Thanks everyone. So far really enjoying it! Yes the front hydraulic post hole digger was a bit expensive. But I liked that you can mount the head center or on the right side. Then drive down a fence line. In terms of flow yes. If I recall going with the 12 speed increased the flow quite a bit and put the attachment well within the usable range.
You have around 16 gpm with that M7060 vs. 11 gpm with the M6060/M7060 with 8F/8R. I run an HD25 PHD off the 3rd function and it's just about perfectly matched to the flow rate of the MX and M with a range of 5-12 gpm. I'm near the upper end of the range which is the better end to be at.
I'd like to know what options you got with your tractor. I can see that you didn't get the rear wiper and defrost, but you added at least one set of wheel weights. How about rear remotes, creep range, air ride seat etc. I've got just about every option possible on both tractors and have even added functionality in the form of Summit Hydraulics rear remotes. I'll be done with the Scorpion control grip install today but am waiting on a wiring schematic from Summit since I'm not using their control box.
