air in hydraulic lines
Azza
Kubota B8200 tractor plus T1760 ride on
Mar 1, 2023
35
Australia
Kubota B 8200 not been used for couple of months Started and hydraulics worked fine; FEL & slasher. Short while using and stopped functioning, not moving at all. Hydraulics emitting noise.
ctfjr
L3800HST
Dec 7, 2009
1,859
2,229
central ct
Did you check your fluid level? When was the fast time the filters were changed?
Azza
Mar 1, 2023
35
Australia
only done couple of hours since fluid change and filter cleaned. Fluid level checked regularly and maintained to full mark. Previous have managed to release trapped air by disconnecting hydraulic hoses but not working this time
Azza
Mar 1, 2023
35
Australia
uncoupling all three hoses
6,066
Is the tractor not moving at all, or just the hydraulics?
If it doesn't have a clogged filter screen or a suction leak then you're probably looking at a damaged pump or drive.
Azza
Mar 1, 2023
35
Australia
Your contribution appreciated. Tractor works fine
tractor runs fine. I'm betting on air in hydraulics given the abnormal noise . Will check intake lines sn d go from there
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,218
1,007
Williamstown Ontario Canada
Does the 3 pt hitch work?
Hydraulics are self bleeding with use.
However, if your suction side of the pump and the suction line have air leaking in then you will always have air.
Often suction lines have places where there is a rubber joint. These crack and let air in but not fluid out so often best to just replace these pieces.
Hydraulic lines re-installed in the wrong place can cause big issues...........
Dave
4,278
Any air in the line should be gone in the first couple of minutes of operation. I think I would start by disconnecting the power beyond return at the hydraulic outlet block. Stick it in the transmission filler, start the tractor, and watch the flow. It should be steady with no signs of air.
The power beyond hose is the one towards the rear of the tractor.
Azza
Mar 1, 2023
35
Australia
Dave
Thanks for the relevant info Dan / Dave. Will follow up and see what results.
