Air Filter Replacement tight fit
KubotaL185DT
L185 4x4, L245H, M5140HD, Case 580B Hoe, JD350 Dozer, JD LX178,
May 6, 2010
81
Northern Calif
I replaced both inter and outer filters today on my M5140 pushed them into the housing, But when I place the end cap on it took a lot of force with the 3 over center latches. Should I have used silicone on the rubberized ends of the filter so they would slide home. Or is this normal for the Kubota M5140 a real snug fit. Thanks
100 td
Aug 29, 2015
1,776
ɹǝpunuʍop
To be sure to be sure, measure the old verses the new. No idea if this is the case but some filters have a small divot in them to line up with the housing. The whole thing is worth a second look just in case something isn't right and you suck in a gut load of dirt.
KubotaL185DT
May 6, 2010
81
Northern Calif
Called Dealership spoke to shop foreman (seems any mechanic answer) as never the same guy. I asked it they lube the rubberized gasket ends with anything ? He said no Thats how they fit. I may take it apart and use a little soapy water on it and see it it slides in easier. It just seems to me that I had to place way to much force to snap the exterior housing into place.
Creature Meadow
Sep 19, 2016
1,063
135
Central North Carolina
I use WIX filters and on my L4600 to install the cover it is tight. I clean my outer filter every 10 hours when I grease my loader, check oil, top off with fuel, etc. It is tight and when I push on the clips they SNAP in place. I just ensure when I install the inner filter the first time it is pushed all the way in and the outer also then I go with it. I use no soap or silicone to assist.
I understand your concern as I had a similar question.
So far no problems and my ExMark mower uses the same inner and outer filters and the cap is tight on it as well.
