54 inch or 60 inch MMM on a BX23S
Dunslandloy
B2400HSD, 20 Kawasaki Teryx , Woods brush cutter, Befco tiller, Kodiak blade
Aug 4, 2017
59
SE OH
OK last one..... :LOL:
when I bought mine I got the turf tires..... thinking the R4 tires would mess up the lawn....
Well, I recently got a good deal on a set of R4 tars... and I don't notice a lick of difference on the lawn..... and they work much better if you get into mud or soupy stuff if you are doing other work with the tractor...
My R4's do great in the snow and soupy stuff but got me in trouble big time once in mud after a heavy rain.😉 Brother-in-law rescued me with his L3130. He had Ag tread. 🙄😆
Dunslandloy
Aug 4, 2017
59
SE OH
Just about ready to pull the trigger on a BX23S. Was planning on adding the 60 inch MMM (Not the easy-over). But I got to wondering why would someone opt for the 54 inch instead?
Narrower would make it easier to maneuver around trees and such I would think. And make it a little easier to store. But neither of those are going to be things I really have to worry about.
Is there anything about the 54 inch deck that differs from the 60 inch other than size?
Thanks
Martin
One year of scalps with the 60-inch and your yard will conform to your standard with no more back talk. Grass always grows back. 😁 I went from 54-inch on my last machine to 60 on my B and I don't regret it.
Also, once you wear out the Kubota blades, switch to the Oregon Gator high lift blades. Chops grass into confetti. 👌
John T
2017 BX23S
May 5, 2017
1,018
484
under a rock
OK, I'll be the 'devil'. For the cost of the MMM, you can probably buy a good riding mower with 54" deck. That was the case 7 years ago when I bought my BX23S. For me(well neighbours..), it's to dig and haul NOT cut grass.It'd be a real PITA for me ,at 72, to remove loader and BH, install deck every week or so.
No matter what anyone says, we all get older NOT younger, with time !
Kinda agree...
As much as I think my 60" MMM does a good job....
If I could go back to 2017
I would have bought a used zero turn instead.....
just tonight I was fuggin around with the skeleton bucket sifting some dirt and you have to be mindful of the mower deck....
Sidekick
Jul 29, 2023
904
1,129
N.Y,
You can not buy a good riding mower that will last 25 years for that money. Especially if you have hills and muddy areas to cut. My BX has only been a mower and snowblower that has been totally troubled free with recommend maintenance and only burned a little over a half gallon of diesel per hour. I have never had a loader or backhoe on it for the reason you mentioned. You can get a mini excavator for half the price of a backhoe attachment these days that I feel would be a better choice and eliminate the swapping over. Heck, I have been using a $2k Harbor freight trencher for 15 years now that is just as capable as a bx backhoe when needed.
5,571
My grass cutter is a 25 year old Cub Cadet(aka MTD..) ,paid maybe $500 as it was 'used/abused', which was 1/5th of what the MMM deck would have cost 7 years ago. Tough old beastie, even cut down 3' tall winter rye with it years ago. Still the original deck and I have a spare ,just in case.
My point is that a BX23S IS primarily a TLB and not a riding mower, having to change from TLB to mower and back will be a 'pain' especially if you USE the BH or loader often.
Everyone's needs are different. I was going to get a KX-41 but decided the BX23S was a LOT more versatile AND ground speed is 'rabbit' compared to the miniex !
HappyTopster
In the hunt for tractor; Have Honda Pioneer 700, 5x8 trailer, XMark Radius E
Apr 27, 2025
49
20
West of Asheville
I've been happy with my 60" MMM since I bought the tractor in 2017
I just put it back on this week..... aligning the driveshaft is fun...
The only issues were my own doing.... broke off one of the mounts that hold the anti-scalp wheels.... had to weld that back on....
I vaguely remember losing a blade bolt... but luckily found it.... (I now use an impact to put the blades back on)
Oh yeah... and catching the corner of a plastic tarp and sucking the whole damn thing up.... took me an hour to get it out... :ROFLMAO:
Keep it lubed up and the blades sharp you should enjoy it... and keep the RPM's high when cutting.... it's a biggun...
I took all the plastic covers off the spindles and the belts.....
it makes blowing or hosing the clippings out easier...
also hated that plastic discharge flapper.... Yes, you can hold it back with a bungee but then you end up tripping over it... I just removed it....
just need to make sure you don't cut yer feets off when you get off the machine...
seat safetys disconnected..... I grew up in the 70's safety devices do not apply to me. :devilish:
I like the cut of your jib! The 70’s rocked 😎
