4wd doesn't engage F2400
jfroux
F2400
May 26, 2018
Chelsea, Quebec, Canada
Please someone help me!
I have a kubota F2400 1992 I think. I don***8217;t know why but I can***8217;t engage the 4 wheel drive today. The tractor works great other than the 4 wheel drive doesn***8217;t work. :confused: THE LEVER IS NOT GOING IN TO 4 WHEEL. How can I fix it?
5,910
Inside the block on the bottom of the Rear wheel drive lever is a detent (ball and spring) very common for that ball to get stuck and make the lever not move.
So first get some good penetrating oil and give it a good shot and shake the lever back and forth to help possibly break it loose. ;)
jfroux
F2400
May 26, 2018
I also have 2 other issues with my F2400, maybe you can give me good advice. I have a small oil leak for the rear axle that I'd like to fix. The seal between the part that is fixed and the one that moves need to be replace. I'm not sure how big is this job... I didn't find any video on youtube. I also replaced the gearbox bearing that connect to the PTO few years ago but the gearbox was a bit damaged and the bearing didn't fit perfectly (sorry for my english).
5,910
Getting the WSM (AKA service manual) would help you out.
P/N 97897-10287
The seal is fairly easy to fix, no special tools required.
The PTO / transmission rear cover is a simple change out.
Your English is better than most that English is their first language! :p
