B Bill in the U.P. Member Equipment L4630 GST Dec 31, 2020 55 15 8 Michigan Apr 22, 2024 #1 The lever that controls the back blade position recently started drifting down on its own. This is a 2005 L4630. Is there a fix for this?
G GreensvilleJay Well-known member Equipment BX23-S,57 A-C D-14,58 A-C D-14, 57 A-C D-14,tiller,cults,Millcreek 25G spreader, Apr 2, 2019 9,965 4,091 113 Greensville,Ontario,Canada Apr 22, 2024 #2 Most have some form of compression spring to adjust tension on 'holding' the lever. Have a look at an online parts page to see 'how-it's-made'.. Reactions: 1 user
TheOldHokie Well-known member Lifetime Member Equipment L3901/LA525, B7200DT/B1630, G2160/RCK60, G2460/RCK60 Apr 6, 2021 7,012 3,392 113 Myersville, MD windyridgefarm.us Apr 22, 2024 #3 Bill in the U.P. said: The lever that controls the back blade position recently started drifting down on its own. This is a 2005 L4630. Is there a fix for this? Click to expand... Looks like the tensioning is provided by the feedback lever. Item 80 is the friction disk, items 110 look like bellville washers, and item 120 is the hex nut that holds everything together. Try tightening the nut a flat or two to see if that helps. Dan Reactions: 1 user
B Bill in the U.P. Member Equipment L4630 GST Dec 31, 2020 55 15 8 Michigan Apr 23, 2024 #4 Fantastic TheOldHokie. Thank you.
