3 point hitch low lift capacity
4,668
Hello Dan,
Good news! I installed the power beyond plug and it fixed the problem!! My 3-point lift capacity is back. :)
Thank you so much for the help.
Question, would it hurt anything to hold the Summit lever active, and operate the splitter with the lever on the splitter cylinder? I would just tie off the summit lever with a bungie or something.
Thanks,
-Mike
It will work but not the best way to go. What I did many years ago was put a quick connect on the loader valve power beyond. Then when i wanted to use the log splitter I just disconnected the power beyond and plugged one splitter hose into the QD on the valve and the other into the WD on the hose. Essentially the same way Kubota handles the back hoes. Just remember to shut the engine off when connecting/disconnecting the splitter.
