2009 B3200 trans filters. Which goes where?
motorhead
2009 B3200, 2007 Dodge/Cummins powered Ram 2500 395hp
May 17, 2012
423
21
Atascadero
At 200 hours, it's time to change the hydraulic/HST oils and filters. My question is I have a WIX 51361 and WIX 10285. The first filter, 51361, is listed as an "Oil filter" and the 10285 is listed as a hydraulic filter. So WHICH goes where?
Also, I have read about a strainer at the bottom.
Any help appreciated.
whitetiger
Nov 20, 2011
2,611
1,130
Kansas City, KS
Kubota HST filter HH660-36060 Wix 51361 Left side of the tractor
Kubota Suction filter HH670-37710 Wix WL10285 Right side of the tractor
There is a screen on the Left side right by the filter, 26mm head, 1 1/6" will also work. Unscrew it, was it out and reinstall it. There is an o-ring on each side of the tube the screen goes through.
Creature Meadow
Sep 19, 2016
1,063
135
Central North Carolina
whitetiger, excellent response to the question.
No snarky comments about it is in the manual, you can do a cross check on the Wix site or whatever.
Posters like you are why I joined some years ago to help me with things I knew little about and maybe along the way I've shared some useful knowledge as well.
Not everyone is good with computers or searching the internet for answers to questions they may have. Heck I got some friends that don't even have internet where they live and still use flip phones.
Not intending to hijack the post just wanted to recognize a great response to a question.
Jay
johnjk
Apr 13, 2017
1,291
904
West Mansfield, OH
I changed my filters at 148hrs since I purchased mine used. I did not pull the screen and check it at that time. Do you know how much fluid will be lost when you pull to check/clean? I should be at 200hrs this fall and will do a complete fluid/ filter change at that time.
motorhead
May 17, 2012
423
21
Atascadero
People like you on sites like this makes this site valuable. No BS, Just information. Thanks for the Info!:)
motorhead
May 17, 2012
423
21
Atascadero
I feel like a rookie, even with 55 years wrenching. I cannot find the MAIN trans case drain plug. I see the two, one on each side of the differential BUT not the main drain plug. 2009 B3200.
UpNorthMI
May 12, 2020
850
566
Up North, MI
You will see the main drain plug on the attachment below, it's listed a (1).
Good luck with your work.
motorhead
May 17, 2012
423
21
Atascadero
Thanks. One thing different on the diagram is my oil filter is up on the side.
