1996 L3600
Dconnell
L3600
Mar 16, 2024
Savannah
Just bought my first Kubota. I will be leaving this tractor at my hunting club. My understanding is one key fits all.
Is there an upgrade ignition that would provide a bit more security?
5,128
Nope, Pull the battery out and hide it.
3,036
My ‘96 Kubota has two *start-safety switches….the Range Lever MUST be in ”Neutral” for the starter to operate. That switch is not obvious…. it is under the deck near the Range Lever mechanism.
UN-plug the leads at that switch… They are simple male/female connectors. Unplugging them will disable the starter.
It has another safety-switch… the PTO lever must be Disengaged also. I suppose one could disable that as well….
One could “lock-wire” the fuel shut-off/shut-down also.
