Hello friends. I have a broken spot where the long pin that holds the two lower links for the 3-point hitch attaches to the transmission case. You can see in the pics that one side has broke free from the case. I've been told it will need to be taken apart (tranny case removed) in order to weld it correctly; clean and also w/o risk of heat damage to internal seals, etc. So I'm looking around right now to hire a mechanic to do this for me, but also considering doing it myself. How big of a job and will the entire tranny need to be removed or is it possible to remove only the rear half (differential case) ? Any advice would be greatly appreciated.
