16mm Wheel studs
Ironbrew
R410B, L4850DT, Z411
May 4, 2024
15
Vancouver Island
I need to replace some wheel studs on my L4850 due to calcium corrosion. Kubota wants $20 Canadian each not including the nut. Does anyone have a source with better pricing that will mail to Canada or located in Canada? I had hoped to replace all 16 but at that price... ugh...
woodman55
L6060HSTC, RTV 1100
May 15, 2022
812
615
canada
Some 16mm threaded rod may be a idea. You would want grade 8 (10.8 metric) and the correct thread pitch. Cut to length and install with red locktite, or even a jam nut on the back side.
Ironbrew
May 4, 2024
15
Vancouver Island
This is my backup plan if I don't find proper studs at a reasonable price. Or, at the very least, have a piece on hand for emergencies...
2,607
If the studs are threaded in rather than pressed in, and it’s a through hole like on like on my tractors, then I think what I would do is find some grade 8 bolts that are threaded all the way up to the end, and screw them in from the back, and perhaps cut them if needed. I don’t know if this kind of a bolt is available in grade 8, but I imagine it is.
I would not use threaded rod unless it was graded high enough for that kind of use, as IronBrew mentioned.
Ironbrew
May 4, 2024
15
Vancouver Island
It's threaded
I can get threaded rod in grade 10.9 (roughly metric equivelent to grade 8). It's on my next town run list.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
2,587
1,359
WestTn/NoMs
When I replaced bolts and studs on my L35, I ordered them from Fastenal. But then I found they were only about $4 from Kubota, too. Just shows the vagaries of Kubota parts pricing, I guess.
4,492
oopsy, I was looking at the FRONT wheels on parts finder and yes REAR wheel studs are $20 each.
somehow thought you were looking for fronts( maybe cause I have 3/4 bald front tires...)
While the cdn kub 'oarts finder' has a few quirks the prices ARE accurate. At least my local dealer ,Galer', always charges those prices.
3,881
It's threaded
All studs on tje Grand L? My Standard L has two studs and four bolts. You could do like many new car makers and do all bolts if you wanted.
3,881
US price is $15 so about the same given the exchange rate.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
812
615
canada
After what theoldhokie said, I checked the parts for my rear wheel. Your stud is used in a lot, of machines including mine. Mine uses two of the studs and six bolts at 3.23 each, pt# 0107351640. Plus some washers. This might be the way to go.
No code has to be inserted here.
Ironbrew
May 4, 2024
15
Vancouver Island
Solved the issue by ordering the BroTek 2" spacers. I need them anyway...
