'16 Kubota 5660SUHD - Not Starting - Sitting for two years
Gweesh
M5660SUHD - M6040
Apr 13, 2024
I have a 5660SU that has been sitting for two years and am attempting to start with no luck.
Here is what I've done so far:
-Drained fuel tank, Had gunk in the plastic splitter on lower tank hose keeping it from draining. Cleared out.
-Followed line to Fuel strainer, intake port of Strainer was clogged, cleared it out and got good fuel flow.
-No Fuel to injectors, loosened injector Fuel line, still no fuel.
-Traced back to fuel filter, Filter IS filling up with fuel, I did bleed out the air as well
I've yet to tear into the main Injector pump, and am wondering If someone has done this before. Could the Injector pump be seized up? I read there Is a Shutoff Valve that is prone to getting stuck? I assume the junk I have found downstream in the lines kind of indicate the finer tolerance components might be gummed up as well?
To summarize, No fuel Is getting to Injectors, Fuel is getting from Tank to Fuel filter, Further than that I am not certain where I should look before tearing into larger parts. The Engine Is turning over fine and I can hear the round fuel pump working and It has decent pressure.
5,166
You need to take a step back.
This is an Electronically controlled fuel injection system.
It does not follow the rules of a mechanical fuel injection system.
The pumps that control the fuel are VERY EXPENSIVE and VERY PRECISE.
These are not pump you randomly take apart and tinker with.
There is no shut off or stop solenoid on these types of fuel systems.
First get the WSM and read how to troubleshoot the system.
You will notice that at some point in that troubleshooting process it going to tell you to take it to a dealer, follow it.
Venturing past that point will normally just end up costing you a ton of money!
Look at the dash for codes, those codes will tell you what's not happening.
follow the WSM to see what steps are needed to fix the issue.
Gweesh
M5660SUHD - M6040
Apr 13, 2024
Thank you for the info, I will look at the WSM. The dealer said it was mostly likely the pump, they quoted me $4k for just the pump, so I was searching for other options first.
3,869
The price of storage can get very expensive. If you are not going to use a tractor for a few years, have the dealer prepare it for long-term storage or post a note on the calendar to go out and start it every month. The same thing happens with old car collections, they sit for a couple of years and then it is expensive to get them running again.
4,222
Generally good advice, but......
I leave 2 cars, and 3 tractors alone for 6 months each year while I am in Florida, and have never had an issue.
I do keep a battery maintainer on all batteries.
I did not start my Ford 8N for 9 years.
It needed a battery, fresh gas, points filed, and a new condenser.
5,166
Ok you can try this at your own risk, I assume Zero responsibility... Unless it works. ;)
First make sure you are getting fuel to the pump input, (RED) just crack the banjo bolt and check.
If you are then pull the SCV out and clean it (BLUE).
Check all fuses.
You might need to reset the computer, The WSM should tell you how to reset most codes.
Gweesh
M5660SUHD - M6040
Apr 13, 2024
Check all fuses.
Thank you sir, I will try this and report back.
Gweesh
M5660SUHD - M6040
Apr 13, 2024
Check all fuses.
Did all above and still no fuel to injector lines.
I have diesel coming out of Red Input line, not high pressure but it is flowing.
Pulled SCV and blew it out. I Also noticed when turning engine over fuel does seep out of SCV hole.
I measured resistance of SVC @2.9ohms it says in the book it needs to be 2.1ohms?
I also measured the SCV pigtail voltage, it is at 8.45 volts WSM says its supposed to be battery voltage or around 12v.
Haven't found out how to clear codes yet, display does not show any at the moment.
4,093
re: I measured resistance of SVC @2.9ohms it says in the book it needs to be 2.1ohms?
Did you measure what the resistance was when you shorted the two probe leads ?
You need to subtract that from your 2.9 reading...
Gweesh
M5660SUHD - M6040
Apr 13, 2024
In that case it's 2.8 ohms. So could the difference from 2.1 to 2.8 keep it from functioning properly? I took it off and it does function when key is turned on although sounds odd while activated?
I'll order the SCV and see of thats the problem.
Again, I measured the voltage from the pigtail and it read 8.45 volts, I think it needs to be 12v? Hopefully the ECU is not fried.
So far... I can't seem to get fuel passed the fuel rail.
3,869
Throwing parts at a problem without understanding if the part is defective or not is a waste of money and time. Sure you might get lucky and it will solve your issue, but more than likely it will not. If you don't understand the systems and have a working knowledge of the tractor systems then you will save money by having someone familiar with Kubota repairs fix the problem for you. Changing parts can introduce many other problems that you might not know about, and if it is an electrical problem you can do more damage than the original part. If you broke your ankle would you try to set the bones yourself or would you go to someone that knows what they are doing who will set the bones correctly the first time?
Gweesh
M5660SUHD - M6040
Apr 13, 2024
Great point! Thanks for the input, I believe that's what I'm trying to do; lean on some of you here who may know a thing or two about the systems or may even had this problem before.
If you look at previous posts I'm trying to deduce what might be the problem before bringing in the big guns.
Gweesh
M5660SUHD - M6040
Apr 13, 2024
I did contact the local Kubota shop today and they said i might simply need to tighten everything up and crack a single injector at a time and keep cranking until I see fuel.
