New clutch wont release
Skintraditions
B6100a
Feb 17, 2025
Alabama
Hey guys a newbie here i got a question about a kubota b6100e
I just installed a new clutch ,pressure plate, throughout bearing and pilot bearing. Got it back together and the clutch will not release. The same problem as before but the throughout bearing was making a noise so I replaced everything. I need help tracking down the problem. I've adjusted it every which way even a Lil tight I can press the peddle till the clutch fork rod hits the inner bell housing .
Could the clutch fork be wore if so how can I tell and where could I find a replacement
7,766
Other reasons that could be why is not working.
If the Flywheel has been turned.
Bad pressure plate
Disk bad (too thick)
Wrong parts
Flywheel or disk or pressure plate got or had any moisture on it when assembled.
I did one that once and dew settled on it overnight, put it together, set for a couple days then was stuck hard, had to disassemble and clean it up.
Clutch fork worn, broken, or installed backwards.
