M4900 Hydraulic Problems. Power steering, PTO are OK. Everything else weak
wheelinag
M4900
May 16, 2025
20
La Grange, TX
Well now I'm even more confused. I took the main relief valve out again, disassembled it, put it back together and in the tractor. Started it back up, still have the gauge hooked to the "in" port hose. Had it running for a couple of minutes while messing with the adjustment of the relief valve, I heard a noise and the gauge shot up to 1300 psi. I was at about 1800rpms. 3 point is now not working.
I shut it off and then started it back up again and now I have under 700psi again.
4,847
About 99.9% sure. Here is valve I took out and inspected. And yes, I hooked the gauge directly to the hose.
Not sure where to go from here. Is there another relief valve in the 3pt system? I'm hesitant to mess with the pump because I think I'll just end up with the same result.
d youd youv
Pretty sure you got the right relief valve. How did you go about setting the adjustment screw?
Ideally the next place to go would be a pump discharge pressure test but thats not an easy test to plumb up on that tractor.
4,847
Thats encouraging and sounds very much like the relief valve is misbehaving. Three point wont work because your gauge has power beyond blocked.
Try that again. Watch the gauge as you turn the adjuster in. Pressure should increase as the screw is advanced. System setting is 2700 PSI.
wheelinag
M4900
May 16, 2025
20
La Grange, TX
The sound came from the front. I'm assuming the pump area since the pressure line isn't hooked to the loader.
I can tell when the relief valve is doing something as when I back it all the way out, like to a 100psi, I can hear a change in the engine. When I screw it in a little, which only gets me back up to 500-700 psi, I can hear the engine change again.
It definitely has some volume going through it. Just for curiosity, I took the gauge of the line and put it into a bucket open flow. Probably shot out half a gallon pretty quick.
Are these pumps 4 bolt flanges or something proprietary?
4,847
In the parts diagram pump looks like a 4 bolt flange but whether its standard or not ?????
Damn relief valve is $500 !!!! Before poppimg for that I would do a pump discharge test. Do you know how thats done?
4,847
The WSM procedure involves a ($$$$) flow meter.
You can accomplish the pressure portion using this test rig:
  1. Remove the delivery pipe from the pump and connect an adapter plate.
  2. Connect the adapter to a tee with gauge in the middle.leg
  3. Put a 3000 PSI needle valve on the third leg of the tee.
  4. Run a hose from the needle valve to the hydrauluc filler
Fully open the needle valve and start the tractor. Then slowly close the needle valve while watching the gauge. Pressure will begin to climb as you clise the valvr. Stop closing the valve when you get to 2700 PSI.
wheelinag
M4900
May 16, 2025
20
La Grange, TX
Perfect, make sense to me. I think we have all of this at the shop. Will look in the morning. Thanks again for your help.
wheelinag
M4900
May 16, 2025
20
La Grange, TX
Striking out again. I ASSumed the hard tubing coming off the pump into the 3 point case/axle was a JIC fitting, it's not. It has come kind of rubber looking feral. I'm hoping the fitting it goes into is o-ring boss. Trying to confirm that after lunch, before I tear it apart further.
4,847
I knew you were overly optimistic :cool:
I think you will find those are metric compression fittings. The case itself MAY be BSPP.
You need a pump adapter plate. Easy to make if you can get the bolt spacing
