I bought a M4900 in January of this year with 593 hours on it. At 600 hours, I changed all fluids and filters. Everything has been working great. I ran an auger with an adjustable top link for over 500 holes and my brush hog also uses the remote. FEL has being working well. Tractor now has 643 hours.
Today I'm mowing 16 acres and at the very end I notice that I can't lift the mower any more using the remote. That prompted me to check the loader, which the lift didn't work and the curl barely works. I checked the fluid and it was a little low. Filled it up and no change.
3 point arms immediately drop when I shut it off. If I rev up to 2300RPM's I can get the loader to barely move up. The remote won't pick up the mower, but I can see the hydraulic line move like it's getting a little pressure.
I researched a little bit and figured out there are "two hydraulic systems", but not sure how that works yet. Steering and PTO work fine, I know those are on the priority system. From diagrams it looks like the flow goes from the pump into the 3 point case, but I haven't gotten any further than that. I also check the 3 point control linkage and everything is connected. I also tried many positions of the 3 point resulting in no change.
Suggestions? Where do these systems split the primary vs secondary parts?
Thanks in advance.
Thanks in advance.
