No oil pressure after rebuild
Bgblock427
M7040, L4240 and ZD1211
Jun 21, 2024
25
9
Tennessee
I need a diagram of the oil circuit for a 3307 engine I don't see one in the manual.
If you have seen my previous posts I rebuilt a 3307 engine for a friend that we had problems getting parts for.
The engine fires up perfectly but no oil is getting to the oil pressure sensor. I verified that using a mechanical gauge that there is no oil.
My guess is one of the small expansion plugs under the front cover didn't need to be there. I checked the pump when it was apart and yes the o ring from the pick up tube was installed. I will be pulling the oil pump cover off today (not looking forward to it as the tractor is all back together.)
Hoping someone has a diagram on here, always a help! Thanks
or a photo of what plugs needed to be installed under the cover.
8,284
Yes if you put a cap/plug where the red is there that is 100% your problem
That is an oil galley
The plug should be in the green spot only.
If you pull plug 100 (Yellow) you will see the cap/ plug in the block
Bgblock427
Jun 21, 2024
25
9
Tennessee
Yep. pulled the cover and the plug was in the hole, I feel better because I didn't install that plug the machine shop did. I can tell and the hit around the edges with a chisel to keep it from coming out. Checked oil and no glitter, engine was only ran a couple of min, so fingers crossed it didn't hurt the bearings. Ill post a pic later.
Bgblock427
Jun 21, 2024
25
9
Tennessee
Well here was the problem, once I seen it was staked in place I knew it was done by the machine shop. I do automotive engines so I didn't catch this on assembly. But when customer said no oil pressure I remembered the galley plugs in the front thinking they were for antifreeze and not a oil passage. At least it only took about 1,5 hours to get to the problem, now to reassemble and call it good.
