Rear hydraulic hose interference on lx2620
Squirrely Baker
20
11
Idaho
Ive got rear hydraulics on my lx2620 for top and tilt. The problem is, I cant raise and tilt the box scraper without it bumping one of the hoses off. I have tried to route the hoses far enough away from the manifold(?) but no avail. Every time I raise it, it knocks a hose loose. Anyone else have this issue? Any solutions?
1,782
Add a 45 or 90 degree fitting between the hose and coupling half so the hose can rotate when you raise the 3PH
1,782
Your local hydraulic company will have them on the shelf.
on line places like discount hydraulics will ship them to you.
You will need to figure out the threads and size of the hose and coupler.
3,107
1,708
I will look into this. Not sure where Id find the fittings or what size but thank you, ill dig around.
Make sure you use fittings designed for >2000 psi. Not plumbing fittings from Lowe's, HD, TSC or local hardware store.
4,856
That looks like OEM remotes BUT why are the two top link hoses attached to upper and lower couplers? Factory install is side to side - each block contains A and B ports for a single valve.
Squirrely Baker
20
11
Idaho
I have no idea. Are you sure about this? Assuming so, is this a problem, or just the mechanic thinking it wont matter? If this is wrong, Im going to start a problem for them. Im kinda irritated with it all.
4,856
I am sure each cylinder should be connected to just one block. I am not sure what you have in that picture.
My personal opinion is the hose routing is terrible. Here is the top link on my L3901 for comparison. I used live swivel hose ends on the cylinder ports to cut down on binding when the lift is raised and lowered.
Squirrely Baker
20
11
Idaho
Its a headache for sure. The dealer is gonna have to fix this.
BAP
Dec 31, 2012
2,878
984
But Dan, you are forgetting that while the parts page shows it hooked up this way, that doesn’t mean that the person who installed it hooked it up this way. They could have very hooked up the feed lines in the back side of the outlets in a vertical orientation, NOT a horizontal orientation.
4,856
Not forgetting anything. Trying to ascertain what the installer did. That was my point.
Squirrely Baker
20
11
Idaho
An update on this for anyone having similar issues. I understand its not an uncommon problem for these tractors so hope this helps.
Salesman and mechanic came up after work today (stand up guys). After a little head scratching they came up with a good fix. They flipped the bracket holding the hose coupler upside down and repositioned the fittings/hoses to keep them clear. Pictures below will explain it better than I can. Note the orientation of the screws on the bracket holding the hoses. They just flipped that bracket upside down, which effectively moved that hose coupler to the right, just enough to allow the top cylinder to clear as its raised and tilted.
Before
And After
Everything is clearing as it should now, raised tilted and everywhere in between. They did place the stop on the position control lever to limit how far the top cylinder can be raised, but not by much. That was done to prevent the fitting on the top cylinder from hitting the rear glass when fully raised (a known issue, from what i understand). Its only very slightly limited and it raises plenty far off the ground.
Hats off to Clayton at Mountain West Equipment in Rexburg for top notch after sales support. Second time he's come through for me.
