Looking for Row Crop Tire Sizes for M8560
m8560gilroy
m8560
Nov 3, 2024
15
Gilroy
Hey everyone,
I'm trying to switch my Kubota M8560 to row crop tires — the thinner ones for better maneuvering between rows. My current tires are:
  • Back: 16.9-24 R1
  • Front: 9.5-22
I didn’t get much help from the dealer, so I'm hoping some M60 series owners can pitch in with the correct row crop tire sizes. Any advice or recommendations would be greatly appreciated!
Thanks in advance
WhatsApp Image 2025-03-28 at 1.13.26 PM.jpeg WhatsApp Image 2025-03-28 at 1.16.11 PM.jpeg WhatsApp Image 2025-03-28 at 1.17.29 PM.jpeg
3,026
1,663
Hey everyone,
  • Back: 16.9-24 R1
  • Front: 9.5-22
Thanks in advance
View attachment 151298 View attachment 151299 View attachment 151301
The front-to-rear axle ratio on the M8560 is 1.405, unlike the 7060 and 6060. The M5-091 has the same hub dimensions and axle ratio as the 8560. You can Build a tractor on kubotausa.com to see their tire options for an M5-091, but it looks to me like you have the narrowest Kubota offers. Some have larger wheels and look narrower, but I think it's only because they're taller.
m8560gilroy
m8560
Nov 3, 2024
15
Gilroy
Thank you. I am fine with regular tires and thin tires is just a want, you might be right. I want the taller tires for clearance as my tractor touching the plants strawberry plants right now.
m8560gilroy
m8560
Nov 3, 2024
15
Gilroy
My Kubota is 2014.
3,026
1,663
There are also some options for narrower tires for the M5-091N narrow model, but I'd check the rolling circumference, since I'm not sure that model's axle ratio is the same.
m8560gilroy
m8560
Nov 3, 2024
15
Gilroy
Where is the official info for the ratio? I am unable to find over the internet.
3,026
1,663
I think @eserv was the original poster of this data.
8,073
You actually have non standard tires on it right now.
These are the 2 stock options for the taller tires
Front 12.4-24
Rear 16.9-34
Front 12.4R-24
Rear 18.4R-30
m8560gilroy
m8560
Nov 3, 2024
15
Gilroy
Thank you.
Found a used ones from a private seller with rims, 16.9-R34 back and 13.6-24 front. I am really anxious what if they mess up with MFWD mechanism if not of the proper ratio? Where can I really confirm or double check? I will be peaceful if someone using this combination. I also found that these tires used on JohnDeere, is that okay? Do they interchange?
8,073
The fronts are not the right size, 12.4-24 is what you need.
The 13.6-24 might work, but would need RC of both tires to know for sure.
3,026
1,663
Can you measure them before you buy? You can measure the circumference of both tires at the largest point, divide the rear by the front, that should be maybe 5% less than your table ratio.
Also check the bolt # and circle, and hub hole size on the wheels.
