Can you upgrade the injectors on a B1750?
mpoteete
B1750
Apr 1, 2025
Georgia
I have a Kubota B1750. I have an injector that is leaking. I was wondering if there are larger injectors available or any type of upgrade. Maybe get a little more power out of this thing.
Thanks
Mike
ruger1980
L4310 w/La682, L225
Oct 25, 2020
448
160
CNY
Fuel delivery is controlled by the injection pump not by the injectors.
mpoteete
B1750
Apr 1, 2025
Georgia
Thank you. Could I turn the pressure up or is there no adjusting these? Sorry for the stupid questions, I am new to the tractor side. Been a hotrodder my whole life though.. so I always see some room for more power..lol
jaxs
B1750HST
Jun 22, 2023
842
646
Why certainly. If you got the money,there's shops specializing in diesel engine hot rodding. As millions of pickup truck owners learned the hard way, there's more to it than bigger injectors,jacked up pump or propane injection unless you only need it to run like a bat out of hell for a short period before throwing a wiggle pin or bending the wobble shaft.
mpoteete
B1750
Apr 1, 2025
Georgia
You are correct.. so I guess no turbo in my future..lol. after all it is just a little tractor for the little farm.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
448
160
CNY
It is not pressure but volume you must increase. There is an adjustment that limits the travel of the rack. By changing this it increases or decreases the max fuel that can be delivered. A little goes a long way.
Just remember you are dealing with an engine rated at 20hp. You are likely not going to get 30hp out of it. 10% is probably a realistic expectation.
5,394
2,081
ain't gonna get much more out of it until you can get more air into it.
you can turn the pump up a little but you might be wise to put a pyrometer on it, and keep a close eye.
jaxs
B1750HST
Jun 22, 2023
842
646
Or trade up to bigger tractor. Why do people want to abuse these little tractors anyhow? First they ask "what is the largest_ _ _ _ _ can I use on my,,,,,,,,,,,,,,," then they want to know how to squeeze more horsepower from their engine. In the end they wonder why there's coolant in oil pan and exhaust is like a whistling tea kettle spout.
