Hydraulic issues
broncobandit71
B2650
Mar 30, 2025
washington
so any ideas as to why this would detonate here? I had been running the tractor at normal limits for moving dirt work. I was scraping a thin layer of dirt when I hear a pop and had hydraulic fluid fan out on the left side. shut down immediately. I believe that part number I have found is correct but when I try to look at any pics it just shows no photo of the part. part# 6c430-36030 assy case, hyd cy
I have a 2018 b2650
5,504
I 'think' this might be it ?last digit is '2', yours is '0' . If so ,about $1300 CDN , ouch. Looks 'kinda easy' to replace though BUT I'm wondering about 'bits and pieces' might have got INSIDE ? Others will know the how and why
4,743
I have a 2018 b2650
It serms to be a common failure. Some possibilities:
  1. Overloaded 3pt
  2. Defective safety valve
  3. Defective casting
1,611
I think I saw a similar situation here where the implement was raised and the tractor was going across the furrows and the “shock” of that did the same thing. I think I see a landscape rake on the three point hitch in your pictures. Did you happen to be going through some rough terrain when that happened? I assume that there is no chain holding the implement up.
broncobandit71
B2650
Mar 30, 2025
washington
Yes there was a spring rake attached but it was in the raised position. I was still working with the bucket. Once the unplanned event happened the 3point went down and the bucket was already on the ground....
4,743
Thats exactly the scenario Russell is talking about. Hydraulic pressure in that cylinder is holding the rake up and as you move around over rough ground it bounces generating pressure spikes in the cylinder. The pressure safety valve in the cylinder is supposed to prevent the spikes from over pressuring the cylinder but...
Orange man
Kubota L2501 LA525 loader , woods prd6000 mower, Land pride RB 1672
Jul 23, 2014
218
123
WNY
Messicks Kubota says they have one in stock, so you are not the only one to have the problem.
Orange man
Jul 23, 2014
218
123
WNY
I do not see a safety relief on that cylinder, like other tractors, maybe that is the issue?
broncobandit71
B2650
Mar 30, 2025
washington
Ahhh I see what was being said now. Sorry.
4,743
It is internal - just a poppet valve teed off the pressure side of the pidton. Having seen several reports like yours I think the issue is bad casting design and/or owners putting excessive overhanging load on the 3pt generating spikes to large for the design to handle.
Orange man
Jul 23, 2014
218
123
WNY
Ok,Sorry I did not see one, the l series has one right on end of cylinder.
broncobandit71
B2650
Mar 30, 2025
washington
Sorry I guess I answered your question in my head. Yes that was a spring rake attached. No rough area I was actually making a flat area for parking a travel trailer.
JonM
Kubota Grand L6060
Nov 29, 2024
14
wisconsin
how much does your rake attachment weigh. how far out is most of the weight. from what i could find a b26 has a 3 point lift around 1600ish pounds .
so if your rake weighs a lot and sticks way out bouncing can easily damage the hydraulics over time.
