Aesthetically pleasing support for barn lean to fly rafters?
trackman23
MX4800
Nov 22, 2023
102
19
NC
I am looking for suggestions on how to improve the looks of the support for my lean to fly rafters. I have 2’ overhangs all the way around this barn / shop and the lean to rafters are 17’ long.
You can see the two areas in the photo that I am trying to improve the looks of. The “ledger” beam doesn’t bother me too much but if I keep it I will replace it with a pressure treated one. The beam extension at the rafter end is the one I’m not a fan of.
Suggestions welcomed! Thx.
3,402
I would extend both boards all the way across, so it looks like it was part of the original design.
3,402
Meaning, add another 2x10 to support the fly rafters and make it look like an original beam?
I don't know how to circle things on my Mac like I do with PC, but
In the upper RH corner, where you circled it, that small 4 footer looks like it was an after thought and it's supporting the last ~2 feet?
Ideally I would try to tear out that original 2x10 and replace it with one that extends out fully.
If that is not an option, then I would "double up" that 2x10 with nails and construction adhesive making sure it extends all the way out.
Then splice a short piece (on the front side nearest the trees) in to make the 1st 2x10 "appear" to look like one piece.
Kind of like you "originally intended" to use a "doubled up 2x10" in the first place. (thats my story and I'm sticking to it :D )
trackman23
MX4800
Nov 22, 2023
102
19
NC
Got it. It is already doubled but I can make it a triple and maybe clip 45deg of the bottom outside corner. It would be a pain to replace the beam entirely but the hurricane straps are not on yet...so not impossible.
4,818
You don't need either of them. Not sure why you even put them in.
The ends of the rafters get tied together when you nail up a face board on them.
trackman23
MX4800
Nov 22, 2023
102
19
NC
Confusion with the framers. The idea was to eliminate blocking since I didn’t want to see a bunch of blocking but when I came home, I had blocking and beams.
trackman23
MX4800
Nov 22, 2023
102
19
NC
just saw your edit. The rafter tails will be left open so no face board
4,818
If that's the case (I thought you did the framing) I'm betting that your framers only put them in temporarily so that they could hang the outboard rafter and nail it in. I'm thinking that they will be removing both of them when finished.
InTheWoods
B7510/FEL, B7100D, ZD18, ASK-R130
Nov 17, 2023
221
169
Indiana
Yeah - that does look bad. I've just added extra 'short' 2x4 roof purlins from the fly rafter back one or two rafters. If you have carpenter bees, treat these purlins accordingly - I wrap mine in window screen.
1,847
I don’t think this is what you’re really asking about but search “rafter tail designs“ and see if that can resolve the issue. If you have open tails it would improve the looks there but nay be difficult to cut now they are up.
You should see something like this…
4,818
Wait. Can we clean up the confusion here? I'm assuming that the OP was referring to the scabbed 2x's that are supporting the outermost rafter identified in the red circles...correct?
Those are temporary supports/guides for attaching the outermost rafter (the face/overhang). It's much easier to nail it in while supported (by the scabs) at both ends.
I'm quite certain that they wont be permanent.
edit, just saw your note about the blocking. Yes, the blocking would need to stay in place.
Dustball
2016 B2650HSDC
Sep 15, 2023
402
254
Hudson, WI
You could take off the last rafter and have the lean-to die into the side of the house.
Here's how I did mine-
trackman23
MX4800
Nov 22, 2023
102
19
NC
Correct. I am referring to the 2x6 that was scabbed onto the beam and the 2x6 sticking out from the corner of the barn.
BAP
Dec 31, 2012
2,893
1,010
If that was done by a builder and not yourself, I would be seriously questioning their building skills. That looks like it was done by a first grader with no prior building skills.
Dustball
2016 B2650HSDC
Sep 15, 2023
402
254
Hudson, WI
have to ask what's the horizontal chimney for IN the carport ?
I have a gas heater in the garage which was in place for years before the lean-to was built. I did extend and turn the vent using two 45 degree elbows up and went through the new lean-to roof after the picture was taken four years ago. The termination is now 10 feet away from the windows above the roof.
