BX2670 instrument panel
dkforge
L2501DT, BX2670 - (loader, MMM, snowblower)
May 10, 2014
9
North Central, PA, USA
Going to have to replace the instrument panel($422), water made it's way in this winter and froze damaging the tach needle and panel. Any suggestions on how to clean this connector so I don't end up having to buy a new wiring harness also ($600+).
I've always kept it under a carport but that was damaged this winter and so it had to sit outside.
Thanks for your help
Sawdust&Shavings
Apr 25, 2023
58
37
Stafford, VA
My BX lives outside year around but I have a 3’x6’ weatherproof tarp that protects it from rain and snow.
5,469
After you've cleaned ,dried and confirmed it work 100%, consider using 'dielectric grease' to help keep moisture out of the connector. Same stuff you use for trailer lights. Everybody has a favourite brand of 'grease'.
zd user
zd-18 b7100hst
Jun 10, 2016
newtown pa
HI I use white vinegar .put that connector in a cup of it over night .then rince with hose .blow it dry with air compressor blow gun .i do car electronics repairs .and road salt sure screws up under body harnesses .rear camera and tail light problems .once blown dry apply die electric grease
Tractor Gal
BX23D MLB
Oct 30, 2020
536
189
NC
Here's an ebay deal on sub-compact cover...$39.00
If you're in Canada, here's the same deal:
https://www.ebay.com/itm/3256043501...jC9wjIUteAn6wiw1WHuAGwPQ==|tkp:Bk9SR_zTmoi5ZQ
These look pretty good to me...but what do I know?
Tractor Gal
Hugo Habicht
G1900
Jun 24, 2024
251
307
Ireland
I found vaseline very good. It is used a lot on boats, a very demanding environment for any electrical contact.
