Kubota B6000 Aux Hydraulics
7,991
Easier to cut the pressure line in half and install hose fitings for a pressure takeoff and power beyond return.
EDIT:
Looks like a B6000 has a factory hydraulic outlet block in the pressure line
Some do and some don't have the block.
I don't think the gray model B6000's had it.
That would be great if he did have the block, he could get a plate from Torch and use that.
4,732
If not a tubing cutter and two compression fittings accomplishes the same thing.
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
321
122
Attalla Alabama
mossycreekoutdoors.com
Send a PM to @Mountainman and ask him if a cover off a B7100 will fit a B6000, if it will the b7100 cover has a valve built in that directs the fluid different directions, either Aux or 3 point.
Yes the standard cylinder cap is the same between b6000 and b7100 so you could put a valve cap from a b7100 on a b6000
