How to remove the steering column cowl
PennMan
B7500 HST
Mar 12, 2025
NEPA, Pennsylvania
I am trying to access a safety switch on my 2001 B7500 HST. It’s located near the clutch pedal but it’s underneath the cowl that conceals the steering column. There is speed lever(turtle/rabbit) lever I need to remove in order to remove the cowl.
Does anyone know how to remove this lever? There seems to be a pin holding it in place. It’s not threaded, not an Allen wrench, star wrench, or square. I have tried to carefully knock out the pin with a with hammer taps, it does not move. Help.
8,062
Are you trying to get to the switch for the clutch?
It's a roll pin, use a pair of vice grips to grab and squeeze the pin, then using a twisting motion to get it out.
You can also use a drift punch to help it come out after you clamp it with vice grips.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,297
1,495
Near Lancaster, PA, USA
It often works best to use a very light hammer with sharp blows. An old spoon is always in my gun tool kit. Its heavy enough to do the job in many cases.
Shadetree605
kubota b2100
May 1, 2022
224
108
north little rock, ar
that is a roll pin, a small drift punch and hammer will knock it out.
