Quick release pin for Landpride RCR 1248
marrmanu
B2620 3pt chipper, box blade, post hole auger, custom 3pt chain box with hooks h
Jan 16, 2021
117
90
usa
Not sure what size quick release pin for my Land pride RCR 1248. Its 1 3/8" yoke 6 spline. I see pins for sale stating fits most domestic style yokes. Land pride part number 00.02.01-44.5 is not coming up in parts search.
Thx for any help.
2,982
1,626
Have you checked with your dealer? This doesn't seem to be available separately from Kubota/Land Pride.
There seem to be at least 2 styles, if you post pictures of both sides we may be able to identify it.
My pin has a small diameter pin on one end. You put the spring in the hole, then the small end of the pin, when the end comes out of the small hole, you squeeze a keeper in the groove to keep it from popping out.
The other kind uses a washer staked in behind the spring. There's a shoulder on the pin and a counterbored hole in the yoke to keep the pin from popping out.
2,982
1,626
Big end approximately 5/8 small end 7/16 with smaller shoulder down about 1/4 inch.
Here's two that fit Bush Hog, I think mine is the second one. It's not nearby or I'd go look.
EDIT There's a picture online of the 76062, but I don't think it's the right part.
marrmanu
Jan 16, 2021
117
90
usa
Do you have a driveshaft shop nearby? Maybe if you take it in they could help?
No shop nearby, I'll try messicks with those stock numbers and my drive line numbers.
