Looking for wheels for an R400 Kubota
7,767
Looking for 1 to 4 wheels (Kubota pn 68817-24860) for an R400 Kubota loader. Or do you know an aftermarket source. I am in Vermont.
Get the lug count, Lug size, Lug spacing, and Center hole size and offset of center.
Rim size and rim width is a bonus.
Tire size is 12.5/70-16 right?
If so the rim width should be like 10" and 16" dia.
Landscaperjim
Kubota R400
Mar 12, 2025
Norwich, Vt.
This is what I have so far. Kubota part # 68817-24860, 6 lug, tire size 12.5/70-16, tires are still on so I might have to guess rim width. I will measure in the morning. Thanks, Jim
7,767
There is three different rims used based on the serial number of the unit.
I don't know what the difference in the rims is.
Sometimes it doesn't amount to much, other times the newer parts will not fit at all.
<=20016
68811-24853
>=20017
68817-24850
>=20271
68817-24860
Landscaperjim
Kubota R400
Mar 12, 2025
Norwich, Vt.
Thanks Wolfman. The serial number is 20709. The center hole measures 5 7/16". The holes for the studs measure 3/4". The distance from the edge of the center hole to the center of the stud hole is 3/4" as well. The wheel measures 17 1/2" across. The width of the wheel is approximately 12". Attached is a picture of the front and back of the wheel. All four of mine are rusted through near the edge of the lip and the tire guys say the changer machine will likely destroy them.
7,767
It's a 16" rim the 17 1/2 is an irrelevant number.
You need these measurements
To get lug center to center:
To get the offset:
To get rim width:
